Breaking Plastic Gears??
w6br
Thud Driver
Aug 28, 2013
42
Gentlemen,
I am having some frustrating moments with my new G8688 Lathe!! It seems that when I attempt to do some cleaning up of round metal and I lock it on the Lead Screw, I wind up shearing the 80 tooth Plastic Gear for the Lead Screw. I have replaced the Plastic Gear twice now and it still continues to happen?? I know there are metal gears available, and these are not on my priority list, there are other truly needed things that I want to purchase. Perhaps that is the answer??
I have made certain that I have adjusted the adjuster properly, I think, according to the manual and other reviews.
Any suggestions and help??
Thank you and have a Merry Christmas to All, and to All a Good Night!! :)
Ron, w6br
Hi Ron,
a new lathe sometimes may be a little tight. the plastic gears might not be up to the task.
i would recommend the use of steel gears to remedy your problem.
a general inspection would also be a good place to start too,
since i have no idea the materials you are trying to turn and a whole lot of variables i can only speculate on.
but i'm willing to help out in any event!
What is your feed rate and depth of cut? A high feed rate and deeper cut will increase the torque load on the gear. An improperly sharpened tool bit will also increase the the torque load. If there are high spots on the bar you are turning or you are making an interupted cut, the momemtum of the drive train could create enough torque to shear a tooth.
Bob
Make sure there is .002-.005 end play on the lead screw, if it is binding it could cause this. Also too much backlash can cause this. I used to keep my plastic gears right up against each other. Make sure the half nuts are adjusted properly and not binding the lead screw. Make sure the apron isn't binding on the ways. I switched to all metal gears for change gears and internal gears and think it was a very worthwhile upgrade. They are noisy but they don't act an expensive fuse. You can stall the motor with them. Also all the other posters have given great tips on this.
I'm thinking something is binding on the leadscrew or carriage. Otherwise maybe gears are set too tight?
http://www.mini-lathe.com/ is a great source for "tune-up" tips on the 7x lathes.
I did quite a bit of adjusting my 7x10 prior to doing much with it, but the pushed it pretty hard.
I took some pretty heavy cuts on 2 1/2" cold rolled bar without any damage.
All was good until I crashed the tool post into the chuck (yeah, that was bad)
The crash actually broke the plastic gears in the headstock. A metal gear upgrade and new 16" bed from LMS and I'm pushing it harder than ever. Still using the original change gears, although I had a little damage byt the keyway slot on the 80 T gear.
I would say to the opposite of what royesses said. I used to find that if the gear mesh was too tight then this would mash up the gears teeth. Set you gears mesh by placing a piece of paper between the teeth and tighten them up.
Sent from my SM-N920C using Tapatalk
Hi Ron,
You didn’t say, so I’ll ask just for the sake of clarity, does the plastic gear break before or after the tool comes in contact with the work piece? Does all seem okay when the carriage is on auto feed but not cutting anything? Also, what is the metal, the rpm and the feed rate. In my experience and observation, if you give the guys on this forum enough detail, one or more of them will solve your problem. (Don't ask me how I know that. ;))
Tom
First of all, let me thank all of you who have so generously given of your time to answer my question!! :)
I was turning a piece of Brass approx. 2" dia. and just wanted to clean up the outside surface. The Lathe was running about 1000 rpm and running smoothly. I had run it about 3 times with a feed of roughly 0.010" with the Power Feed on. On the third pass roughly in the middle of the piece I heard a loud pop, and no more power feed. The Lead Screw 80 tooth Plastic Gear sheared off approx. 3 teeth and producing a flat spot. Every time the gear comes around to that spot it stops. I had already replaced one 80 tooth gear due to warpage, and this was the new one. No, I did not use paper to size the clearance, but I adjusted the adjuster so that the Gear ran true and smooth (perhaps not??) After checking everything out I noticed that the reversing lever in the back was not mating well in the little detents to hold it in place. The spring is solid. I did check all of the operations before using the Lathe and cleaned and adjusted and lubricated the Lathe per mini-lathe.com instructions which are very detailed but I followed the instruction very closely. Like everything else, I could have missed something??
With the carriage on auto feed and not cutting anything it did run fine, as well as when cutting. Now, I was using a carbide tipper cutter with little infeed. I feel that I did not use very much pressure on the cutter and part, there again, what is little to me, but may be overload?? What I feel are defective parts, poor finish and assembly. I will truly go over everything again and double check all adjustments and purchase a set of metal gears. It is a sturdily built little lathe, and I feel with some TLC and some re-assembly patience and correct assembly, I feel that I will have a good running Lathe. What say you??
What was your depth of cut. Remember brass trends to hog in which can cause issues.
