    Dismiss Notice
Brand New Harbor Freight Band Saw Pulley Messed Up!!
Discussion in 'HARBOR FREIGHT, CENTRAL MACHINERY & BUSY BEE' started by Wisrianni, Feb 16, 2016.
  1. Wisrianni
    Wisrianni United States Active Member Active Member
    3
    8
    City:
    Philadelphia
    State:
    Pennsylvania
    -Return to Top-
    just got a new HF band saw and noticed a loud noise in the pulley housing opened it up took the pulley off put it in my lathe and bam saw this.
    what a joke.
  2. Billh50
    Billh50 Active User H-M Supporter-Premium
    961
    113
    City:
    New Britain
    State:
    Connecticut
    -Return to Top-
    I would take my camera and the saw back to HF and tell them I want another one in exchange. I have had no issues with mine other than alignment of guides to cut straight. I fixed that myself with a shim in the right place. Also our local HF has no problem taking stuff back if within the warranty time.
  3. Chip Maker
    Chip Maker United States Active Member Active Member
    107
    43
    City:
    Slinger
    State:
    Wisconsin
    -Return to Top-
    I don't think you should be so fast in condemning HF so fast. These kind of things happen with many of the suppliers from time to time. I would first call your local store and see if they will just give you the pulley before you have to load the saw up and take the whole thing back. To be really nice they may even give you one off a saw they have in the store instead of waiting for one from their parts department. I guess I just don't let this kind of thing bother me to much if they handle the repairs. Seems odd that just the outer part of the pulley is all that is out of wack. Good luck !!!
  4. Billh50
    961
    113
    City:
    New Britain
    State:
    Connecticut
    -Return to Top-
    I thought the same thing about only the outer part being out of wack. My first thought was maybe the saw took a good hit and bent the end of the pulley somehow. And if that was the case maybe the transmission had some problems because of it. That was why I suggested getting a different saw. Either way stuff does happen from time to time and I know I have had good experiences with HF and would not put them down over 1 or 2 problems with things.
    My experience with Inspections of Parts in a production house is this. Depending on the quantity in a production run depends on how many they randomly check from that run. If they get no problems from the ones they check, then the whole batch is accepted. That does not mean that there are no bad ones. So on occasion someone will get a bad part. This happens even with the best manufacturers. It is when it happens quite often and with no help rectifying that I will say something bad.
  5. brasssmanget
    brasssmanget Active User H-M Supporter-Premium
    63
    48
    City:
    Oak Creek
    State:
    Wisconsin
    -Return to Top-
    Kinda makes one wonder if those aren't three separate pieces pressed together.......
  6. stupoty
    stupoty Active User Active Member
    207
    63
    City:
    London
    -Return to Top-
    Just a little run out then.
    Looks a little like the had the part slip after the first two larger V grooves were cut.
    Stuart
  7. TOOLMASTER
    TOOLMASTER you don't want to know Active Member
    1,046
    113
    City:
    SOMEWHERE
    State:
    Minnesota
    -Return to Top-
    hows does final qc miss that
  8. Billh50
    961
    113
    City:
    New Britain
    State:
    Connecticut
    -Return to Top-
    Only reason I thought it got dropped is because even the hole is running out on the end. I would have thought the hole would be running good on end if the V was turned off center.
  9. stupoty
    207
    63
    City:
    London
    -Return to Top-
    Ow, humm yeah, thats odd. I can't even imagine how that works. When ever I've seen aluminium that bent or bashed I would expect massive ripples where it's kinda squigge'd or maybe tearing.
    Stuart
  10. kd4gij
    kd4gij United States Active User Active Member
    1,072
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
    Just take the saw back and get another one. I always open things up in the store before I buy it if possible , if not when I get it in my truck before I leave.
  11. TOOLMASTER
    1,046
    113
    City:
    SOMEWHERE
    State:
    Minnesota
    -Return to Top-
    THE BORE SEEMS TO RUN TRUE
  12. kvt
    kvt Active User Active Member
    578
    113
    City:
    San Antonio
    State:
    Texas
    -Return to Top-
    I have even had things like craftsman power tools bad from the box. They do not really inspect most things like a final QC any more. They do the random checks and if that is good, then the whole lot or the lot for the day is considered good. And the poor smuck that is board to tears putting the pulley on does not pay any attention to it he just slips it on and tightens the screw down.
    The think looks like it the last was cut on a offset. maybe they were trying to make a cam.
  13. Billh50
    961
    113
    City:
    New Britain
    State:
    Connecticut
    -Return to Top-
    When I put the video up to full screen and look when it shows the end the end of the bore is running out. I don't know about the end against the chuck.
  14. TOOLMASTER
    1,046
    113
    City:
    SOMEWHERE
    State:
    Minnesota
    -Return to Top-
    The h saw i bought years ago seized in about a minute...no lube at all in the gearbox :confusion:
  15. Getsome
    Getsome United States Iron Registered Member
    2
    3
    City:
    Milton
    State:
    Florida
    -Return to Top-
    Mine out of the box had problems also. The set screw for that pulley was stripped out. I had to drill and tape it bigger before I could use it.
  16. royesses
    royesses United States H-M Supporter - Premium Content H-M Supporter-Premium
    362
    63
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    My local HF won't cannibalize a display machine. They require an exchange machine or a call to HF for a replacement part.
  17. Heckle and Jeckle
    Heckle and Jeckle United States Active Member Active Member
    41
    18
    City:
    Earth
    State:
    Georgia
    -Return to Top-
    LOL, this reads like HF is selling off seconds & returns from Northern tool. I remember when HF was a flier sent, junk mail 1970, print stank then, just as the stores now.
  18. Billh50
    961
    113
    City:
    New Britain
    State:
    Connecticut
    -Return to Top-
    I have had some good luck with most of the stuff I have bought there. Being on a low fixed income keeps me from buying the top brands anyway. My 4x6 bandsaw is about 10yrs old and still works good. Had to replace the motor though because the plastic fan inside broke and froze the original. But I can't complain as it lasted 10yrs before it broke.
  19. Reeltor
    Reeltor United States Active User Active Member
    245
    43
    City:
    Lawrenceville
    State:
    Georgia
    -Return to Top-
    I'm surprised to see a machined aluminum pulley. When I was in the market for a horizontal band saw (the smallest, manual one that they sold) the display model had a stamped steel (mystery metal?) pulley. One of the reasons that I didn't buy a HF unit. What saw is this off of?
    In any case---Return the entire saw; even IF parts are available, it will take months to have one shipped from China. As you said, the damage done to the pulley may also have caused some hidden damage that wont show up until 1-day after the warranty.
    Mike
  20. Billh50
    961
    113
    City:
    New Britain
    State:
    Connecticut
    -Return to Top-
    Most of the pulleys I have seen on the chinese tools are cast. The bore, keyway, and setscrew hole are the only things machined.
    Ulma Doctor likes this.
  21. Smithdoor
    Smithdoor United States Active User Active Member
    68
    28
    City:
    Clovis
    State:
    California
    -Return to Top-
    I have found most tools made china need work
    At less it was low cost if it was my saw I would just new pully
    Dave
Share This Page
