- Mar 24, 2011
- 108
Hi everybody,
I am building a Brushless DC Motor, mostly from scrap material. It is a 100 mm OD outrunner and it is just a prototype to test my design and calculations.
I started with this DC generator, that I bought for 4 euros in a scrapyard and would provide the rotor drum.
The DC generator was dismantled, cut, turned and drilled and 2 end covers were manufactured from scrap aluminium.
The rotor will receive 12 magnets on the inner surface, which must be equally spaced, so this magnet spacer was made from PVC water tubing.
Finally the rotor drum was assembled; it is completed with the 2 end covers.
I've already done some work on the stator, built also from scrap material, but I will write about it once it is finished.
By the way, this work was done in a full size workshop and not in the mini lathe that I have in my garage.
