I am painting my DoAll 16" vertical bandsaw. It is equipped with a blade welder. The welder has a small grinding wheel for the weld finish. Anybody know what motor this should have? As I received the saw it had been replaced with a larger motor. That required them to make "extensions" to bump out the welder for clearance. Works OK, but looks cobbled. I'd like to replace the motor with one that fits correctly while I have the saw apart.
So anybody know what motor it should have?
I should have mentioned that this saw is an oldie. Blade welder is DBW-1 if memory serves. I'll have to double check that.
