    Dismiss Notice
Biggest Project with a 3" Chuck
Discussion in 'MINI-LATHE & MINI-MILL INFORMATION' started by crossthread, Mar 25, 2017.
  1. crossthread
    crossthread United States Swarf Registered Member
    0
    1
    City:
    Dunlap
    State:
    Illinois
    -Return to Top-
    I need small parts at times and am considering buying a 7 x 14 lathe. I want a small lathe that can be moved out of the way for storage when not in use.
    What is the biggest project you have successfully completed on a 7 x 12 or 7 x 14 mini lathe with a 3" chuck?
  2. Les B
    Les B United States Active User Active Member
    8
    18
    City:
    Livingston
    State:
    Texas
    -Return to Top-
    I have been able to rebarrel my rifles and make almost any item for my projects. Large size objects to turn can be a slow process as the motor will not be strong enough. After I retired I decided to buy a small lathes to see what can be made up. The round parts must be smaller than 13/16 in. to pass thru the headstock. You need to make a special 4 screw chuck with a hole of about 1.200 in. dia. to set the barrel deep into the headstock for chambering. A short floating reamer holder to fit the tailstock and this will allow for the chamber reamer enough distance to use on barrels to size 2 in most barrel makers which is the standard weight for a hunting sporter. Last week I was able to turn down a Krieger to 16.5 inches and fix the barrel extension for my AR15 to make up a 204 Ruger. At one time there was a post on this site of several rifles built with a 7X12. The biggest problem is with vibrations. I noticed that Grizzly has a 4 jaw screw chuck blank for sale. If you go to the Gunsmith section and look at the stock making link to the last stock made you can see the mini lathe in operation on page 4 or 5.
    Les Brooks, retired gunsmith
  3. mzayd3
    mzayd3 Active User Active Member
    149
    43
    City:
    Mayfield Heights
    State:
    Ohio
    -Return to Top-
    Just buy one. You'll get the bug and end up with a garage you can't park in. Is there anything g better in life?
    WesPete66, savarin and cmantunes like this.
  4. crossthread
    0
    1
    City:
    Dunlap
    State:
    Illinois
    -Return to Top-
    Thank you Les. That is the type of information I was seeking.
  5. cmantunes
    cmantunes United States Active Member Active Member
    15
    8
    City:
    Herndon
    State:
    Virginia
    -Return to Top-
    Yeap! :)
  6. crossthread
    0
    1
    City:
    Dunlap
    State:
    Illinois
    -Return to Top-
    I am trying to avoid that, but I know at some point I will get drawn in.
  7. Les B
    8
    18
    City:
    Livingston
    State:
    Texas
    -Return to Top-
  8. Dan_S
    Dan_S Active User Active Member
    533
    93
    City:
    Champaign
    State:
    Illinois
    -Return to Top-
    On most lathes, the size of the chuck isn't what usually limits you, its the rigidity of the machine, and/or the power of the motor.
  9. chips&more
    chips&more United States Active User Active Member
    1,071
    113
    City:
    Danville
    State:
    California
    -Return to Top-
    My intent is to not talk you out of buying a lathe. But, the lathe will need tooling. And need material/stock. And the lathe will need an operator. It will be a learning curve. You will need time to do all this. To say you need a small lathe to make small parts and then put it back on the shelf when done. Is not like grabbing the hand saw to make that 2 minute cut and then put the saw back on the peg board. What you are asking is a time and money involved idea. I hope I didn’t scarce you away? I hope it was just a heads up so you will need to prepare better.
    Ken from ontario likes this.
Share This Page
