Mobil Vactra 2 is ISO68.Will the iso 68 oil recommended for use in the gear box be acceptable to use on the fill holes and ways on a pm1236 or should I get some way oil?
On my PM1236, the oils/lubes I use are:
Vactra #2 for the ways & ball oilers on the carriage, cross slide, compound slide, & tailstock
Velocite #10 for the ball oilers for the threading leadscrew/power feed shaft ends, & gearbox shaft (located behind the gearbox cover).
DTE Heavy Medium (ISO68) for the headstock, gearbox, & apron.
Motul C2 chain lube for the open spur gears.
