Benchmaster MV-1 General Questions
Rick_B
H-M Platinum Supporter
Dec 10, 2011
446
Hello all - i usually spend my time over in the south bend wing but i'm considering a Benchmaster MV-1 purchase and have a few questions. i-ve read a lot of threads here and elsewhere and fo.ks seem to fall into two camps - a benchmaster is well bilt'but too small and a benchmaster is an ideal machine for'the typical home shop needs. assuming i have accepted the size limitations - what should I be looking at in terms of machine condition, tooling that is necesary or specific to the machine and anything else I may be missing. logistically what is the size and weight -i'm wondering if it would fit in a small SUV (RAV 4). Finally'what is the relative value'ofthese machines assuming good condition and excluding any tooling.
thanksfor yourhelpand thoughts
Rick
I would buy a Benchmaster in a heartbeat, and replace my minimill with it.
You should be able to get it in the Rav4 with no problem.
200 lbs. Put down a piece of heavy plywood to spread the weight.
http://www.lathes.co.uk/duro/
thanks guys - i'm going to see it up front amd personal this afternoon. I'm pretty sure it is a vertical which from'what i have read leaves a pretty small working envelope. the small working envelope, lack of power feeds and lack of a quill seem to be the most often mentioned negatives. I believe the vertical will work with steel as well as aluminum/brass/bronze. The asking price is high - $1000 - which starts to approach a used bridgeport - on a very good and lucky day.
Rick
Other than E-Bay and craigslist (which is hit or miss in my area) is there another place to find Benchmasters for sale?
Thanks
i went and looked today the machine seems in pretty good shape - everything seems tight with very little'backlash in the table movements. Not much tooling goes with it - a vise, a couple'of collets, lots of end mills and some misc stuff (some parallels, 90° angle plates, surface gage, etc). after some comversation we ended up at $700. I didn't commit but seller agreed to giveme a few days to think about it.
Rick
No pictures yet - but I did talk witxh the seller today and we reached an agreement at $600 - I'll be picking it up'tomorrow and will post some'pics
Rick
Well I picked up the new to me bench master today - you can say a lot of things about them but you can't accuse them of being lightweight :). Some pictures below - the machine is still resting peacefully on its side until I wire wheel the stand and get some paint on it. I don't want to move this any more than I have to.
the first few pictures are of the machine and stand
Under the base - I was expecting to see some rust here but nothing
The machine itself (serial number 8674) - the discoloration is more grime and dirt than surface rust.
and the stand
finally the motor - 1/2 hp craftsman 1750 single phase
The next pictures are the "accessories" that came along for the ride
This was a box full of stuff (Vee blocks, parallels, a sine plate, various clamps, surface gages, some reamers and a bunch of other stuff that I'm not yet sure about). Unfortunately there is some corrosion - some pretty serious - but I'll see what I can do to clean it up. I believe a lot of this was user made.
next was a user made shelf with a drawer - more stuff in the drawers - reamers, more clamps, drill chuck, etc.
Finally was a box of end mils - 173 to be exact. I'm betting there is a lot of junk in there but I also think there is a good supply of useable end mills
I'm feeling like I did OK with this deal.
Any thoughts about putting a mobile base under the stand - would that be detrimental to the machine operation?
Thanks
Rick
All my mills have mobil bases under them.
That certainly came well tooled.
You will probably want a real milling vise early on.
Also a holdown clamping kit.
Nice score! :man:
AR1911 - ok a couple of'questions
first the mobile base - others have suggested that leveling a mill is as critical as a lathe and a mobile base cojnteracts the leveling - any thoughts?
second - what is a real milling vise - are you referring to the lower profile vises I habe seen? any suggestions or links to one that would be the appropriate soze for this mill? is the vise that is on there more'of a drill press vise?
Finally - not sure what youmean by hold'down clamps - can you tell memore about that?
as you'can tell this is a'whole'new'experience forme
thanks
Rick
