    Dismiss Notice
Bench Grinders
Discussion in 'GOOFS & BLUNDERS YOU SHOULD AVOID!' started by jbolt, Jul 15, 2017.
  1. jbolt
    jbolt United States Active User H-M Supporter-Premium
    901
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Angry with myself today. I recently bought a new Jet 8" 1hp 3600 rpm bench grinder to augment my 7" 1800 rpm Baldor. In my haste to get it up and running I made my first mistake, I did not bolt the grinder to the bench. My second mistake was not ring testing the new Norton 3x grinding wheels before installing them. Apparently the 46 grit wheel was damaged and on spool-up it broke in half as it neared full speed. The wheel guard contained the wheel halves but with the sudden stop of the wheels all the stored energy had to go somewhere resulting in the 60 lb grinder jumping off the bench onto the concrete floor. Quit amazing to see. This resulted in breaking one of the cast iron tool rests, cracking the cast iron base and bending the mounting bracket for eye safety shield. Fortunately the motor shaft and cast wheel guards are undamaged. I powered up the grinder with the wheels off and then checked for shaft run out with a TDI. After that checked out okay I put the factory wheels back on and powered it up. So far so good. Hopefully the vendor will replace the damaged wheel.
    So secure your grinders and ring test the wheels before installing!
    MrFixIt, BGHansen, terrywerm and 6 others like this.
  2. f350ca
    f350ca Canada Active User Active Member
    1,519
    113
    City:
    Calabogie
    State:
    Ontario
    -Return to Top-
  3. NCjeeper
    NCjeeper United States H-M Supporter - Premium Content H-M Supporter-Premium
    543
    93
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
    Glad you didn't get hit by flying wheel parts.
  4. Charles Spencer
    Charles Spencer Active User H-M Supporter-Premium
    896
    93
    City:
    Worcester
    State:
    Massachusetts
    -Return to Top-
    I would contact the company that sold me the wheel or Norton's or both and explain what happened. Of course the wheel could have been damaged in shipping, but a good company would want to know that too. I'd be interested in seeing what they said and/or did.
    "So secure your grinders and ring test the wheels before installing!"
    Yes, absolutely.
    MrFixIt and eric.grulke.79 like this.
  5. firestopper
    firestopper H-M Supporter - Premium Content H-M Supporter-Premium
    1,352
    93
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    Yikes!
    Glad your physically fine, sometimes our pride takes a hit but we're only humans. You posting this will surely help prevent someone else getting hurt.
    +3 always inspect and ring test.
    Probably could have been worse if the unit was secured. Even after a ring test, I stand to the opposite side of the replaced wheel when starting. Those HS shop safety films really made an impression on me, even after 39 years.
  6. dieselshadow
    dieselshadow United States Do you smell something? H-M Supporter-Premium
    155
    43
    City:
    Joelton
    State:
    Tennessee
    -Return to Top-
    Ring test?
    MrFixIt likes this.
  7. firestopper
    1,352
    93
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    A ring test is conducted by tapping the wheel gently with a light, nonmetallic implement, such as the handle of a screwdriver for light wheels or a wooden mallet for heavier wheels. The wheels should be “tapped” about 45 degrees on each side of the vertical centerline, and about 1 or 2 inches from the outer edge of the wheel. Rotate the wheel 45-degrees and repeat the test. An undamaged wheel will give a clear metallic tone/ring. If it is cracked, there will be a hollow, “dead” sound and you will not hear a clear “ring.” In this case do not use and throw out the wheel.
    dieselshadow and MrFixIt like this.
  8. jbolt
    901
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Well I still have enough sense to stand off to the side when starting up after changing a wheel. I guess I got complacent since I've never had a bad wheel from a quality manufacturer. Lesson learned.
  9. TomS
    TomS Active User H-M Supporter-Premium
    415
    83
    City:
    Redding
    State:
    California
    -Return to Top-
    All I can say is, WOW!! Glad you didn't get hurt.
    Tom S.
  10. jbolt
    901
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Good news is the vendor is replacing the wheel. No argument whatsoever so good on them. I will say this experience now has me seriously considering the CBN wheels.
    hman and firestopper like this.
  11. Charles Spencer
    896
    93
    City:
    Worcester
    State:
    Massachusetts
    -Return to Top-
    Who is the vendor?
  12. jbolt
    901
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Tools for Working Wood
    hman likes this.
  13. 682bear
    682bear United States Active Member Active Member
    69
    18
    City:
    Temple
    State:
    Georgia
    -Return to Top-
    I do some precision grinding at work on a cnc vertical lathe. Our grinding wheels are mounted on arbors that prevent us from ring testing them. I always inspect the wheels before installing the arbors on the grinding heads. If they have any chips or dings at all, they get scrapped. I also DO NOT crank the grinder up until the head is lowered behind the sheild doors or inside the part... I have had a few explode. You never know what the last guy did to the grinding wheel...
    Also, when I scrap a wheel, I remove it from the arbor and take a big ball peen hammer to it. This prevents anyone from being tempted to take it out of the trash and try to use it...
    I am very anal about 'preaching' this to anyone I happen to be training... a couple of years ago, I gave this lecture to a trainee as we were setting up a grinding job. 2 minutes later, we cranked the grinder up (inside the part) and the wheel exploded. He now 'preaches' about this as emphatically as I do...
  14. bfd
    bfd United States H-M Supporter - Premium Content H-M Supporter-Premium
    167
    43
    City:
    nipomo
    State:
    California
    -Return to Top-
    did it scare the brown stuff out of you? when I blew up a grinding wheel it sounded like a shotgun going off right next to me bill
Share This Page
