belt sander thread
Flyrod
Dec 14, 2016
137
hi all - not sure where to post this
it is a project i would like to do, but also i am seeking input and advice b/c i am a beginner
here is a picture of a belt sander stand made by the mfg:
attached are the specs for the baseplate that the motor/sander are currently mounted on
also, there is a tool attachment tray:
the post is 26" and 5" square - I don't know the thickness - would you think 1/8 or 1/4 would be good?
the base looks like cast iron - i cant do that - plain plate could work, but is pretty plain - any thoughts? (would like wheels but also adjustable feet)
the tool tray has the same dimensions as the base and fits between the base and the mounting plate - what thickness steel would you make the tray out of? - and for the tray, just weld a frame and a base? how would you attach the mounting plate to the tray?
thanks for any thoughts or ideas
  • 44541472.pdf
This design looks to me, one that should be bolted to the floor. It would appear to be top heavy. So if going with wheels I would go with another design for the base. You would need something that is a little wider than the top section. (motor , Grinder etc.) Al.
thanks A1 - the oem base is 13" deep by 15" wide - what would you suggest it goes up to? - while it will have wheels, i would ideally also have leveling feet so when in use it would be on 4 feet - does that change your mind?
thanks
