Battery reverse polarity?
I grew up working on positive ground British iron. Yes, you can reverse charge a battery. Not well, but it will show -12 on a meter. Drain the current charge (light or some such load), then charge it normally.
A deep discharge can cause reverse polarity in a cell so it is possible for a small capacity battery it be possible.
Likely best to leave as is and remark posts or if feeling lucky clip a light bulb to it and discharge it then change it.
i learned something today, batteries can be reversed charged - i never even considered the thought.
when i was in my late 20's , i got asked by a friend to do some work on an antique john deere , 2 cylinder- gas and/or kerosene fueled tractor, to use on his ranch.
it had cloth wrapped cables that were falling apart.
i replaced the old cables and all the simple wiring of the tractor with modern wire, cable and lugs.
one thing i do remember about working on the tractor, was that it had 6V + ground electrical system. that has been the only + ground i have seen
the Ol' Deere was really cool to work on and even cooler to drive! :grin:
OK, that is a new one. Is it possible that you had the charger connected backwards? I really don't understand how a battery can switch polarity. Hopefully someone here can explain how this is possible.:confused:
This is just a guess, but I would think that the battery is done.
G'day Jim, yes I guess it is possible that I connect the charger back to front, yet it continued to work for a couple of hours after that, but anything is possible. I'm going to experiment a bit. Even 24 hrs after the battery is still showing 12.5v but neg polarity on the + red terminal.
Oddly enough in the back of my mind where the memory cells are a bit lost. I seem to recall hearing about this once before, quite some time ago, but I don't recall the circumstances or the results.
If connecting the charger wrong way around caused this to happen, I wonder if I connect it right way round will it fix the battery.
Hi guys, I recently set up a LED lamp above my lathe, it required 12v. I had a spare 12v gel cell battery looking for a purpose, so I hooked it up. Nice bright light with it's own on/off switch. I added a small plug pack charger, 1 amp, and capable of floating when fully charged. I also intend to run a few more low power items off this setup.
After a couple of hours running I switched it off and retired for the night. The next day I went to switch it on and the light didn't work, put multimeter on battery = 12.5v ? assuming the new light fitting was faulty I took it down and pulled it apart, Another similar battery was on the workbench so I touched the light wires to it and presto it worked. Went back to the original battery, wouldn't work? checked battery again 12.5v? take a second look at meter -12.5v switched the meter leads around and got+12.5v. hooked up the led light wrong way around, yes it worked. ????
The two batteries are identical 12v gel cells about 2 years old, now one of them suddenly decides to switch polarity, overnight with every thing turned off.
Any clues gentlemen, and ladies? Can I get the polarity to switch back, or can it be used like this.????
Ok so I had to go out into the garage and take some photos. this is the new led light above the lathe on the left, the right pic is a veiw of the lateh squeezed into its corner,with some shelves i made above it filling up with tools. And the last pic is of the battery with multimeter connected showDSCN8071.JPGing 12.1DSCN8071.JPG DSCN8070.JPG DSCN8069.JPG DSCN8071.JPG DSCN8070.JPG DSCN8069.JPG DSCN8071.JPG DSCN8070.JPG DSCN8069.JPG DSCN8071.JPG DSCN8070.JPG DSCN8069.JPG v with neg sign 189713-8b38eb79295d4bfbbb947c3079dd85b0.jpg189714-a762c35bad37b8beec96dcc2b76ffa7c.jpgThe battery has been stable at 12.1 v for 3 days now. so maybe DSCN8071.JPG DSCN8070.JPG DSCN8069.JPG I should hook it up to something and drain it down the recharge it teh right way around and see what happens.
Since it worked for a while, I suspect you started with a hot battery, and the puny 1A charger has a current limiting circuit in it. This would be why it didn't catch fire the first time. I wouldn't temp the luck gods any more. Don't use the charger to drain it down, use a standard inductive load that doesn't care about polarity.
I would discharge the battery and then charge it with some kind of limiting resistor in series with the charge leads. A car
tail light works well for this( #1157 comes to mind). That way it can reverse it's polarity without much danger. I often use
this method on smaller batteries that would be cooked with a regular car charger.
Thanks Randy, not sure what you mean by "hot"battery the battery was at ambient temperature about 18c on the day, and it was not flat as I checked the voltage before hooking it up, it was 12.4v and polarity was correct otherwise the led light would not work it was connected to the light fitting for a while before I connected it to the 1A charger.
I'm not sure what you mean by a "standard inductive load", but I think I'll settle for a resistive load aka a light bulb. drain the battery down and then try to recharge it with correct polarity.
I also know from past experience that when you connect a battery charger reverse polarity you get big sparks, did not notice any big sparks, but yes, I guess it is possible that is what I did.
Just put a light across to discharge it and then when flat charge normally. This happens more often than one would think. The only thing that one can run into is an automatic charger may not start if the battery is completely flat. Either use a manual charger or hook a charged battery in parallel to give the sensor a voltage to start, once there is a small charge you can remove the charged battery or leave them both hooked up until both are fully charged.
Pierre
Pierre
Thanks Pierre, that is more or less what I intend to do. surprised that it is somewhat common.
