I have started to make a ball turner and this is what I did cut a pipe turn it down on the inside to fit the bearings that I had next
got one of my old chisel and turn it down to 11/16 to fit the bearings ok next I cut flat bar 6 '' long
the flat bar is 1/2/ x 2 1/2 bar and drilled a hole in it and put a bushing in it that I drilled to 11/16 next
welded the cut pipes in place next I cut a flat bar to 2/1/2 x 2 1/2 x of a 1/2 bar and drilled a 11/16 hole in it
and welded my axel in and this is part 1 of my home made radius turner ill do the rest later this week
give me some input
I can take it tell me what I can do to make it better:think1::allgood::shrugs: I can take a :*****slap:so dish it out now I am anic:anic:you are :roflmao:
:nono::notthis:I am :watching: this site has the best info on it youall don't know how much that I like to see what in the new post
most of you are very talented at what you do so keep up the good work and post it so I can see what you do one day I may be the one that someone ask 4 HELP
and I hope it can return it
give me some input
