- May 4, 2015
- 3,583
Anybody ever try these on a lathe? Or won't they work because of the dial sizing ? I was just thinking it should work just like on a mill.
Question is, are you planning to go CNC? If so, ball screws are supposed to be the cat's meow. But if not, I'd be cautious. Because ball screws have a pretty long pitch and low friction, they're easily back-driven. If you installed them, you'd have to be sure to lock any movements not in active use. When set up for CNC, you depend on the holding torque of the "idle" stepper
Didn't know that , wouldn't be any good then for normal operations. At least without some kind of snubber to prevent that. I just thought it be better then having backlash on them .
Question is, are you planning to go CNC? If so, ball screws are supposed to be the cat's meow. But if not, I'd be cautious. Because ball screws have a pretty long pitch and low friction, they're easily back-driven. If you installed them, you'd have to be sure to lock any movements not in active use. When set up for CNC, you depend on the holding torque of the "idle" stepper motors.
No, I haven't used ball screws on machine tools myself. That's just some general info I've picked up, in hopes it will be of value to you.
