- Jan 6, 2016
- 34
1952I would say its at least 220v as for phase need to know how many wires there can be attached from main power. open the cover where the plug comes in and take a photo of that, there also might be some model information inside that cover. Also what year is the lathe.
I was wondering if it was original.Should I up-grade to a more modern motor?If that is the original motor with this lathe based on logan's history on the size of lathe its probably a 3/4 hp 1725 rpm motor and as clueless stated most likely a 3 phase one as well.
Not if it works. Open up the junction box and post pictures. There may be diagrams there.I was wondering if it was original.Should I up-grade to a more modern motor?
