Bad bearings? Dah Lih circa 1976 Taiwanese
It looks to me like the quill bearings should be straightforward enough. Commonly, these will be tapered roller bearings. I changed mine to sealed angular contact bearings so no maintenance is required for the life of the bearings.
The upper spindle sleeve, commonly known as a drive sleeve, can definitely affect spindle runout. The axial play may or may not be an issue but if there is radial play then that is not good. You've gotten this far so why not change them out? It looks like they are just held in by the housing; that should come loose when you remove the hex screws at the base. Typically, there are two bearings separated by a spacer and there should be a nut to preload the bearings. I would guess once the housing on top is removed, you can push the whole sleeve and bearings out from the bottom. I'm guessing here but its based on rebuilding several drill presses and my RF-31 mill and the construction in your videos is quite similar.
Yes! exactly. Thanks heaps Mikey. I now have the top bearings out and you are dead right. The bearings are pristine, no sideways play at all and I think I have found what is causing the axial play. If you can see in the photos, it looks like someone has been in there before. The spacer between the 2 drive bearings looks newer than all else and has chuck marks on it. The spacer is half a millimetre bigger than the inner bearing seats as I've drawn in the photo. Do you think the last guy just made a mistake? He got the bore spot on. I just can't imagine mass produced parts having chuck marks on them.
In most cases, there is a nut that allows you to preload the bearings. This makes the length of the spacer between the bearings non-critical. However, if there is no nut then the spacer length becomes critical. The OD of the spacer normally should allow it to touch only the outer race, while the preload nut would apply tension to the inner race of the bearing it is adjacent to. Your spacer looks like it would contact the area between the two races, which makes no sense at all. Maybe the previous owner got it wrong?
Is there a preload nut? If so, where is it? In most cases, it is on top but I don't see it there. If it is on the bottom, I cannot see how you would adjust it. If there is no nut then the length of the spacer needs to be adjusted but I'm not sure how to figure that length out.
What are the part numbers of the upper bearings? I cannot read it in your pics. Two upper bearings? Same part number?
You do not want axial end play in a spindle/quill doing drilling and milling.
6208 I think. Have just gone back to work so will confirm when home and also explain the preloaded nut to the previous post too.
Sent from my SM-N920P using Tapatalk
Could be 6208. They are 40 mm I.D. and 80 mm O.D. 6200 series bearings are very common and inexpensive radial bearings, and are not meant for thrust loads. Assuming they are the original spec bearings. What make and model mill is this, anyway?
It's a Dah Lih circa 1976 Taiwanese. I can't find any info at all on it and can't get a reply from the company.
The locking nut has one of those washers with the bendable tabs and key to keep locked (see photo)20170810_154528.jpg . It goes inside the spindle sleeve side as per the first couple of photos. As mentioned, the only play is up and down because the spacer is larger than the outer race seat.
Also, what grease would you guys use for these bearings? It has a top speed of 2500 but I'm thinking of a VFD to get a bit more out of it.
Okay, I think I see the layout now. It looks like the spacer is sitting between and bearing against the inner races and the nut is on the bottom of the lower bearing and presses against the lower inner race. I'm not sure if that spacer is the correct length; because it is longer than the bore it sits in, it might prevent one of the bearings from fully seating in the bore. If that is so then one of the bearings will be floating and that might be why the drive sleeve has play. I could be wrong about that but it makes sense to me.
Those bearings are shielded bearings. There is some controversy about lubing shielded bearings because getting grease inside a shielded bearing is difficult. Rather than grease them, it is usually suggested that you replace them. Also, if those bearings are original then they are likely past their usual service life. They may spin okay but may behave differently under load. The bearings are cheap and I would consider changing them while the machine is apart. If you do, I would change them to sealed, permanently lubricated Nachi deep groove bearings that require no ongoing maintenance until they wear out.
I would also change to sealed angular contact bearings in the quill. They do not require maintenance either. Tapered bearings are okay but they are all un-shielded, must be lubed periodically and must be preloaded correctly.
EDIT: Okay, check my thinking here. If the two drive sleeve bearings have a spacer that mechanically separates the inner races of the bearings and it is preloaded then the only axial play it can have will be the internal bearing clearances, right? I mean, the outer races are supposedly seated in their bores and the inner races are preloaded and are effectively solid. If the shaft is moving vertically then the only thing that should allow that are bearing clearances and this should be very small (micron range small). If this is true then the axial movement you are seeing suggests those bearings are shot.
I think we're getting somewhere Mikey. The 2 bearings have open backs which face into the bore where the spacer sits. The grease zerk points directly into this cavity too. The outer races are not a press fit and they slide up and down what looks like half a mm which is how much longer the spacer is than the area for it. This makes me pretty sure that someone has home made this spacer again to a slightly longer size for some reason. I know it's hard to explain and I'm probably not doing a good job of it but **** it helps a lot going through it with you guys. I may look into sealed bearings if they aren't too expensive. Onto the bearings in the quill later tonight so no doubt I'll have a few questions about the taper roller ones in there.
