    Dismiss Notice
Back Plate Advice Request For Bed Mount Lever Actuated 5c Collet Chuck
Discussion in 'MACHINE ACCESSORIES (Tables, Vises, Indexers)' started by Uglydog, Dec 23, 2016.
  1. Uglydog
    Uglydog United States Active User H-M Supporter-Premium
    794
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    I local friend picked up this bed mount lever actuated 5C collet chuck for me for at an astounding price.
    The only factory stampings I'm able to find are on the lever.
    Looks like ZAIAR Tool Co. Maybe?
    Perhaps ZALAR?
    I can't find anything on the company... Age unknown.
    Regardless, looks to be in great use-able condition.
    I'd like to fit her with a D1-6 Adjust-Tru/Set-Tru type backplate.
    Currently I'm running a Hardinge-Shogren 5c with an integral D1-6. I've tweaked her so she is better by cleaning and fiddling with the cams and the tightening sequence. While very tolerable she has more run-out than I'd like.
    It's most likely that I just haven't yet stumbled on the correct website, but I've not been able to locate either plans to fabricate an Adjust-Tru/Set-Tru type backplate or a company which sells one for retrofit.
    Overall OD is 5.85 the ID on the nose is 1.75.
    Any suggestions for a plan or a site for purchase?
    Thank you,
    Daryl
    MN
  2. jbolt
    jbolt United States Active User H-M Supporter-Premium
    661
    93
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Will that configuration work on a lathe?
    South bend sells back plates, cam lock or blank. Thick and thin. Most can be purchased through Amazon. http://www.southbendlathe.com/products/accessories/back-plates
    The major nose taper dia. of the D1-6 is 4-3/16" so you might need an adapter between the back plate and chuck.
    Uglydog likes this.
  3. seasicksteve
    seasicksteve United States Active Member Active Member
    51
    18
    City:
    central
    State:
    Ohio
    -Return to Top-
    Most likely Zagar Tool Co located in Clevland Ohio www.zagar.com
    Uglydog likes this.
  4. seasicksteve
    51
    18
    City:
    central
    State:
    Ohio
    -Return to Top-
    Is the handle fixed or does it rotate radially around the fixture? If it is fixed you will most likely need to re engineer so it doesnt spin with the lathe spindle
  5. Uglydog
    794
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
  6. seasicksteve
    51
    18
    City:
    central
    State:
    Ohio
    -Return to Top-
    That company is located pretty near me. I used to print some of the manuals for the products the manufactured. I remember the collet fixtures catalogs and recognized the design.
    brino and Uglydog like this.
  7. Uglydog
    794
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    I've sent Zagar an email asking if this is adaptable to a D1-6. I hope to hear back sometime next week.
    Thanks for the lead!!
    Daryl
    MN
Share This Page
