- Dec 19, 2013
- 73
I am at the before beginner stage. The lathe is a Grizzly G0602. I have just been randomly turning down some steel to see how the machine runs. Now I want to work with more purpose. So I thought I would see if I could take off say .010. This is what I did.
1. Move in the cross slide until the cutter just touches the material, make a note of the reading on the dial.
2. Back off and move to the end of the material. Advance the cross slide by .005 from the touch reading.
3. Make some chips.
Is this the correct process and I just need more practice or is there a better way? What about the no mans land on the dial where you go from forward to reverse and nothing happens (is this the area called backlash)? My results are not consistent, sometimes I am out be a lot and sometimes just a little.
All help appreciated.
3. Make some chips.
