- Dec 25, 2011
- 10,508
Back to the subject of Timken bearings, I disagree that South Bend used good ones and Atlas used cheap ones. In the first place, Chinese production aside, bearing grades tended to be produced like resistor tolerances were. First you made 10,000 of one type or value. Then you tested (graded) until you got as many as you needed of the highest tolerance or grade. Next you lowered the criteria and continued testing or grading for the second level. Etc.
In the second place, Atlas (and Sears) advertising in the late 30's and 40's claimed that the Timken bearings used were "specially selected" or similar terms. Differing only in the specific adectives used from ads from South Bend and others. You can't claim (or at least you can't prove) that Atlas lied and South Bend didn't. The bearings in the Atlas machines have a date engraved on them. Those that you buy at the auto parts store (besides more than likely not being Timken to begin with) usually don't, although may years ago, I had a fair number of ex-auto parts store Timken bearings that did. The date is undoubtedly the inspection date and not the date the lathe was assembled as it isn't unusual to find (there have been enough examples reported here and on other lists) dates on the two bearings in a single machine differing by up to a year. In the derogatory way in which the term is typically used today, Atlas lathes weren't "cheap". They were "relatively inexpensive".
Robert D.
Robert D.
