- Dec 25, 2011
- 10,477
Jeff,
First, your model number is 101.07403, not 0704. Thanks for the serial number and dates. Where did you find the third date? They don't usually have but two.
The allowable runout of a Class 2 bearing cup and bearing cone is .0015", which is additive so the total allowable runout of the two together is .0030". That being said, it doesn't have to be that bad. It just depends upon whether Timken had already met their daily quota for Class 3 that day or not. But you can't count on it. And buying two sets of Class 2 intending to use the best combination doesn't guarantee you will be any better off. However, I would guess that most of the people who have put new bearings into their Atlas lathes have bought the cheapest thing that they could find. But I never heard anyone report their actual results. So ye pays yer money an ye takes yer chances. The original bearings usually last a long time. Unless there is something that you know is wrong with them, I would put the originals back in, set them up properly per the TB, and see what you get. If the runout is excessive, I would bite the bullet and buy Class 3 and be done with it for my lifetime.
And don't forget that you need to rotate the spindle several times in the same direction. Put the lathe in back gear and on the slowest belt positions and run it for a while with the indicator on the register.
That all being said, I bought a set of what I am sure now are Class 2 or even 4 several years ago before I knew that there was a difference. When I pull my spindle later this year to replace the spindle belts, I am going to install the new bearings and see what I get. I'll report here when I do. But it is going to be several more months at least.
