I have recently acquired an Atlas 10d. I determined the "D" designation by measuring the lead screw longitudinal feed at approximately .650 inches OD. There is no cross feed like on the 10F. Most puzzling is that the gear change door has a gear chart that shows the need for the 16 or 32 tooth tumbler gear, yet there in no tumbler gear hanger or tumbler gear assembly on the back side of the head stock or even a place to mount one. The gear change door / guard has a serial number 10d-28, another clue that this is a 10d not 10F.
I have many gears, but have not found the threading chart that aligns with the 10d, No tumbler / quick change assembly.
Can you educate me on what I need to thread with this lathe?
From Ohio - Mike
From Ohio - Mike
