I built a Brooks cutter grinder which is the non-casting version of a Stent. Much as the Bonelle is a non-casting version of the Quorn. I considered the Bonelle but thought the Brooks would be simpler to build and use. It isn't a trivial item to build; line boring the center slide was challenging and some parts of the work head needed a lathe larger than the 7x12 so purchasing and refurbishing a Rockwell 10" extended the Brooks project considerably for me. Build info:
http://www.gadgetbuilder.com/Brooks_Grinder.html
The Brooks work head allows sharpening the teeth on end mills but the flutes needed an additional attachment, as did slitting saws, see:
http://www.gadgetbuilder.com/Brooks_Grinder.html#End_Mill_Sharpening In general, the attachments for different types of cutters are straightforward to build for the Brooks.
However, drill sharpening on the Brooks, while possible, is slow. I built a separate drill sharpener (
http://www.gadgetbuilder.com/DrillSharp.html#Facet4 ) to speed the process because drills (1/2" and under) are the most common cutter I need to sharpen. The Brooks is used for drills larger than 1/2" which I sharpen less frequently.
John
