Anybody mount a Kurt power drawbar on their PM940 cnc?
rodjava
Jan 25, 2017
67
I'm expecting my new PM940cnc to arrive tomorrow.
In the meantime, I wonder if this Kurt Power draw bar would work on the 940.
https://www.kurtworkholding.com/bridgeport-series-std-p-1262.html
It's a used unit that came off a Bridgeport mill.
It's likely that the base of the Kurt unit can be modified to make it work. Anybody mount something similar to the Kurt or a DIY drawbar on their 940 or similar?
Thanks in advance.
Rod in San Francisco
I adapted a Ultron Snap Change system to my PM-932 that was originally designed to fit a Bridgeport. All that's needed is an adapter.
Tom S.
Tom,
Thanks. Any pictures?
I asked Matt at PM and he thinks it should work. Likely needed to modify an adapter plate and change drawbars if needed.
I still would like to hear from other drawbar installs.
Rod
Tom,
Rod
Here's a couple of pictures. In order for the BP length drawbar to work I had to build a riser that replicated the distance through the BP head, or I could have cut and rethreaded the drawbar. I chose not to modify the drawbar.
The assembled unit.
Here's the individual components. The adapter plate on the upper left and the riser on the upper right. I had to make a drawbar spacer (lower right) to set the correct drawbar height above the riser. The plate on the lower left is a bearing retainer that bolts to the bottom of the Ultron housing in the first picture. It's not applicable to what you are trying to do.
Tom,
Thanks for sharing you drawbar build. If I get this great deal on the Kurt drawbar, your
mods with help with my installation.
Rod
