    Dismiss Notice
Anybody Have An Enco 1005700?
Discussion in 'ENCO & RONG FU IMPORTS' started by RonRock, Jul 14, 2016.
  1. RonRock
    RonRock United States Active Member Active Member
    5
    8
    City:
    Underwood
    State:
    Iowa
    -Return to Top-
    I have this Enco mill and a couple questions about it.
    The quill feed handle will simply pull right off of the shaft. The handle and hub that it rides on are on the shaft and held in position with a keyway and key. The handle is held onto the hub with a C clip that I have removed for the pictures. But I can't for the life of me figure out how they held the hub onto the shaft.
    I think I need someone with either the same or a similar mill to help me out here.
    That's just a start, I have a couple other questions about this mill but I start another thread.
  2. cathead
    cathead Active User Active Member
    571
    93
    City:
    Bemidji
    State:
    Minnesota
    -Return to Top-
    I have a #100-1527 Enco mill of about 1995 vintage and it has a ball and spring detent thing on it. I suppose it is possible that
    the construction has changed over the years and it is entirely possible it was made without any holding device.
    Also mine has a small threaded hole down the center of the shaft that has a 7/8 inch or so knurled washer keeping
    the whole assembly at bay. Is there a small threaded hole in the center of the shaft? It would be easy to fabricate up
    something if it doesn't.
    The ball and detent thing is to allow a comfortable positioning of the pull handle. I have since made a triple pull handle similar to
    what one might find on a drill press.
  3. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    2,888
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    You may be missing a piece that bolts on using the two threaded holes behind the handle hub. Could you post a photo of the back side of that handle hub, the side toward the head?
    Edit: Also, what is currently keeping the hub from rotating freely on the shaft?
  4. JimDawson
    JimDawson Global Moderator Staff Member Director
    3,714
    113
    City:
    Sandy
    State:
    Oregon
    -Return to Top-
    All of the ones that I have seen have the end of the shaft threaded and the hub is held on with a screw in the end. Maybe yours uses a set screw to hold the hub to the shaft?
  5. RonRock
    5
    8
    City:
    Underwood
    State:
    Iowa
    -Return to Top-
    Thanks guys. A little late in my reply, my computer took a dump on me and I have been distracted. Still not up and running as it should but I had to check in.
    There is a dimple on the end of the shaft that I thought may be threaded. I cleaned it out and it seems to be just a center point for turning during manufacture.
    The hub slides onto the shaft and has a keyway that keeps the hub located on the shaft. The handle slides onto the hub and has a pin that allows for the handle position adjustment. There is a C clip on the end of the hub that keeps the handle from coming completely off of the hub.
    Bob Korves, You may be right about a missing piece behind the hub. If you look closely at the photos you can see two threaded holes in the hub. So maybe something would be positioned behind the flange on the hub and then screwed into the hub flange through these two threaded holes. That is a possibility, but that would be backwords from how it should have been designed. That would require the screws to be threaded through the hub then into the "holding plate."
    There is a hole on the outer end of the hub that is curious. Seems like there must be something that uses that hole to hold the hub on. But as I said I am at a loss.
    Thanks guys. I'll get some more pictures tomorrow.
  6. Chuck K
    Chuck K United States Active User H-M Supporter-Premium
    78
    48
    City:
    Genoa
    State:
    Illinois
    -Return to Top-
    Isn't there a set screw in the side of the hub holding it to the shaft? I just picked up a similar machine and was messing around with it earlier. It has a broken clock spring and I pulled the handle and hub off too get to it. Mine has a small bolt and washer to hold the handle on. The hub had a set screw.
  7. RonRock
    5
    8
    City:
    Underwood
    State:
    Iowa
    -Return to Top-
    Thanks Chuck K, it has been a while since I looked it over so I will take another close look. Could I ask you to take some pictures of what your machine has? Is your Enco the same model as mine? I have a couple other "issues" with mine and have not had any luck finding any parts or anyone with the same unit to assist me with what my machine is missing.
    I'd certainly be as helpful as I can with any questions you may have with your machine. I'm sure that these mills are out there, but for some reason nobody wants to talk about them.
  8. Chuck K
    78
    48
    City:
    Genoa
    State:
    Illinois
    -Return to Top-
    Lol.....nobody wants to talk about them. Mine is missing the power feed on the table and the y axis scale. I'll try to get some pics of it.
  9. Chuck K
    78
    48
    City:
    Genoa
    State:
    Illinois
    -Return to Top-
    So it turns out that mine is a different model than yours....100-1598. If you look at the pic of the collar with the clock spring in it you can see the divot where the set screw seats. I also took a pic showing the threaded hole in the casting where I removed the set screw. Two things surprised me about this mill. It weighs 2520 lbs. and has a top speed of 4800. 20170418_172056.jpg 20170418_172056.jpg
  10. RonRock
    5
    8
    City:
    Underwood
    State:
    Iowa
    -Return to Top-
    Bummer! That is close but completely different.
    I did take another look at mine today. There is a hole in the hub, but it is not threaded. It is far enough outside on the hub that it would miss the shaft if it has threaded anyway. The shaft that the hub is keyed to has a center drill but it not threaded looks like it was centered for lathe or mill work during manufacture.
    I've looked this thing over and over and for the life of me I can't figure out how they designed it to hold the hub to the shaft. Shouldn't be this hard to figure out.
    [​IMG]
  11. Chuck K
    78
    48
    City:
    Genoa
    State:
    Illinois
    -Return to Top-
    Maybe I'm misunderstanding you when you say "hub". Are you talking about the hub that's still mounted to the head or the hub with the handle?
  12. RonRock
    5
    8
    City:
    Underwood
    State:
    Iowa
    -Return to Top-
    Yeah it is hard to describe without a part number. I'll try,
    This is my shaft, HaHa sounds funny
    [​IMG]
    Here is the hub on the shaft,
    [​IMG]
    Here is the lever on the hub,
    [​IMG]
  13. Chuck K
    78
    48
    City:
    Genoa
    State:
    Illinois
    -Return to Top-
    Ok....I thought we were talking about the hub that holds the clock spring. Your hub is keyed, right? And the lever slides over the hub? I guess at this point I don't know what the problem is. What wasn't working?
  14. RonRock
    5
    8
    City:
    Underwood
    State:
    Iowa
    -Return to Top-
    Yes the hub is keyed to the shaft. the lever slides on the hub. You are correct. The issue is that the hub is not held onto the shaft. It will simply slide on and off of the shaft, if the key is aligned of course.
    There is a grove cut as can be seen for a C-clip to hold the lever onto the hub. I have removed the C-clip as I attempt to cipher this issue out. It has no bearing on the hub to shaft connection.
  15. Chuck K
    78
    48
    City:
    Genoa
    State:
    Illinois
    -Return to Top-
    I guess my question would be...how tight does the hub fit on the shaft. As I think about it, the collar on my Clausing Kondia pulls out sometimes when I am repositioning the handle. I always tell myself that I need to look into that when it happens, but I'm in the middle of milling something and then I forget about it.
  16. Pkranger71
    Pkranger71 United States Iron Registered Member
    0
    1
    City:
    Bradley
    State:
    California
    -Return to Top-
    Not sure if you figured out your hub situation but I have that exact mill. I pulled the hub off to take a look and there is nothing holding it on its just a "tap fit" with a rubber mallet. There are 2 small threaded holes on the hub flange that I used with a couple of screws to remove the hub.
  17. Silverbullet
    Silverbullet Active Member Active Member
    540
    113
    City:
    Marlton
    State:
    New Jersey
    -Return to Top-
    I'd bet there's a spring and ball detent missing that holds it on . Or a similar design that locks it on. Try looking on the grizzly site at there copy , in there breakdown on pdf may show it .
  18. RonRock
    5
    8
    City:
    Underwood
    State:
    Iowa
    -Return to Top-
    Thanks Pkranger71,
    I have not yet figured out the solution. That is interesting that yours is similar although obviously tighter fitting than mine. So do you feel that the hub is designed as a "press" or as you say "tap fit" design? With nothing else to hold the hub onto the shaft?
    You can see the threaded holes in my hub that I assume you mention you used for the screws to remove yours.
    Happy to hear that you have the same mill, I have other questions that can only be answered by someone with the same unit. I'd like to ask, but photos would probably be more helpful than a post.
    Thanks,
    Ron
Share This Page
