6011 works best on DC electrode positive, 7018 is good for AC or DC but you'l get better results with DC. All my welding is done on DC electrode positive .Best to check with the rod manufactures as to the best polarity and weather it should be AC or DC this info should be on the box the rods came in. DC is the most common. If I'm doing any critical welding I heat the rod no matter what it is. All rods will benefit from keeping them hot and dry, even SS like 316L, 309 Half an hour at 150 F in a toaster over works very well. Cast iron will crack depending on the rod an weather you post heat or not. Eutectic makes a great rod for cast, high in nickel burns with a pink arc no heating needed.
Keep a supply of the most common rods, 6011 or 6013, 7018, 316L for stainless. 309 SS for welding SS to mild steel and some cast rods. 3/32 and 1/8 dia rods is all you need. I do have some 1/16 SS for the real small jobs since I don,t have a TIG. And remember practice, practice
