I'll warn ya first - this is my first project on my new used Smithy 1239 machine so I am getting familiar with it. I just got it put together and turned the brass knob for the handle that is in the picture. I used a HSS fly cutter mounted into my rotator base. A little unorthodox but it seemed to work well. I should be able to turn a 3" ball or up to a 4" diameter sweep with the tool. It should also be able to cut concave arcs into the work as well. I plan to put some graduations to help with set up and repeatability but it is pretty easy to use. Again, give me a little slack, I am a novice machinist.
