- Jan 9, 2014
- 3
I needed to make some nuts to fit the X axis stop groove on my Enco mill/drill. The nut has a trapezoidal cross section. Each side is 15 deg. from square.
I found this vise at Sears and for $45.00 it worked out very well for this light duty job. There are pin detents every 15 deg on the angle slide which is a curved dove tail track. There is also a locking screw on the opposite side the set any angle. The vise can tilt 0 -90 deg.
go to http://www.sears.com/craftsman-3-in...p-00924083000P?prdNo=6&blockNo=6&blockType=G6
for more info.
for more info.
