- Mar 1, 2015
- 71
wondering what some of the simple methods used to secure your machine to floor so you never have to worry about tipping machine over .
I got levelers for my PM 935, and while I was installing I worried that it could tip over. I had that happen with a lathe once, it was still hooked to engine life so no damage done, anyway I slowly raising 935 so I can get pad under each leveling stud, they wont go under stud when it is sitting on floor , head is rolled over and table down because I relocated it a few days ago , I kept thinking about machine tipping over and how I could achor it to floor, I know I cant anchor it thru holes leveling studs go into those holes so what do I do?
what I did was get some 4 inch angle iron and drill holes in casting on outside of base, installed concrete 5/8" anchors and locked it loosely to floor, I made sure I could still adjust levelers and not tip over, then when table is leveled I just tight down bolt to concrete anchor and done,
what methods are being used by others is what I would like to hear about. I was going to skip anchoring 935 to floor didn't figure it would ever tip over with small bed, but decided not to take any chances, will also be adding anchors to my 1340GT , I don't think it would ever tip either but since my body has been beat up enough in life I guess I lean to safe side
