Albrecht Drill Chuck Help
David
Sep 21, 2011
299
I had a mishap on the mill the other day and the R8 shank spun out of the chuck. The drill bit caught in mild steel as it broke through and crashed before I could react!
The problem is that I can't get the chuck to release the bit. Im guessing that the torque may have sprung the jaws to a point of not allowing the unscrewing mechanism to work.
I have placed the drill bit in the vise and put as much pressure as I felt comfortable with to brake it loose but no luck.
I don't care about the drill bit but would like to save the chuck if possible. Any ideas on how to fix this careless mistake?
Dave, if it was me I would remove the rear collar and make a fixture to lock it in a vise. Then I would either try a strap wrench to get the hood loose or make another fixture to clamp onto the hood to break it loose. Here is what I have used to get stubborn hoods off and they work well. The smaller fixture clamps onto the body where the rear collar fits and is locked in a vise. The larger one clamps onto the hood near the top of the knurled section with a C-clamp; a few taps with a hammer on the clamp should move the hood. I have yet to see an Albrecht that I couldn't loosen with these plates.
It may be possible that the guide pin is now bent, making releasing the jaws a challenge. Once you get the hood off you can replace the pin with a roll pin cut to size.
I hope the taper socket isn't too messed up.
Good luck!
I love Albrecht chucks to death! But they are not designed to hold and grab bits larger than the shank size inserted into the chuck.
As precision as they are, I wouldn't use them for any drill bits larger than 1/2" for a 1/2" capacity chuck. Any heavy drilling like with S & D bits, I get my 16N out for the job!
Just my two bits worth!
Thanks Dan and Mikey for the information. I may have to try your fixtures Mikey because it will not break loose and I have really twisted on it.
I have several 14N's but was in a hurry just to drill the last hole, so now I pay the price.
Lesson learned!!
David
Dear People
The shank of the drill is usally soft ... cut it off ... set up drill chuck in lathe and drill say 1/16" undersize of the shank and that wiil releve the pressure onnthe jaws.
Batt
Do you have a pipe wrench? I guess it depends on how much time you want to spend removing the drill, but I have found a pipe wrench or a large set of channel locks to be pretty efficient in that situation....yes I have been called a hack before.
Chuck
Put the drill chuck in your lathe and than apply a pipe wrench to the knurled part of the chuck, since it is not of any use the way it is you cannot make any worse. I have opened numerous chucks with this process during my years of employment.
frankie
I too have used a pipe wrench to loosen a stuck chuck. the knurl hides any marks the pipe wrench might leave. always works. yes I do use up to 1 5/8 silver and demming drill bits in my Albrecht chuck. yes I abuse tools that's what they are for. bill
You could wrap soft copper around it and then use your best holding method . The copper will smash into all the grooves or knurling. I think it would be better to just chuck it in the lathe and cut off the drill and drill it out . Drill bit $10.00 chuck $400.00 do the math.
