- Oct 29, 2012
- 1,328
Rereading my post I see that I left a lot of room for misinterpretation. Sorry for being unclear.Actually there this all depends on the belt and gear ratios. If you change the pulley size you will get just as much torque, if you push the motor up to 120Hz, you will loose significant torque and Hp with these old motors and I doubt it will last long. Why go through all the trouble to see if you can burn up the old motor. As, already mentioned, for some odd reason 2 speed motors do not seem to work well on the high speed with a VFD. On the low speed you will have 4 Hp at best. The 2 speed motors I have seen in these machines was a Delta on low speed, a YY on the high speed.
I was not suggesting wiring for high speed or low speed. I was not suggesting going up to 120hz. I was not suggesting any wiring changes at all. Nor was I suggesting any pulley changes.
I was suggesting leaving all the wiring intact and unchanged, and simply connecting the VFD between the mains supply and the power input of the machine. That way original 2-speed functionality remains (until the poor old motor is inevitably put to rest at the hands of PWM spikes). I realize that I was a little hasty in saying so; that is a bit of an over simplification, since the drive would need to be tied in with the start/stop/fwd/rev circuit. I didn't think about it hard enough to mention that part, but I still believe in leaving it 2-speed.
I then went on to suggest that, if I was forced to pick one way or the other to permanently wire it high speed or low speed (because/if for some reason leaving it 2 speed didn't work out <--- that wasn't stated, it was implied, and vague, sorry) then I would pick low speed and I would exceed 60hz. But I agree with your suggestion to wire for low speed and change pulley size, it's a better solution.
Thank you for pointing these things out.
