- Dec 3, 2013
- 1,844
A little more info I should have stated at the beginning, I sometimes have gaps from my brain to the outside world.
I have run a dial indicator on the 3 jaw chuck and on stock in the chuck, the chuck run true, it when I indicate the stock that I am getting the run out. The conclusion I drew from that was that the chuck body is running fine, it's the jaws and the scroll plate that are out. ( I was going to say out of tolerance but I don't know what the manufactures tolerances are).
Thoughts please
I would start by disassembling each chuck, give it a good cleaning and check for wear, burrs, damage etc. Address any burrs with a stone and then lube and reassemble. Check the run-out over a large range, i.e. 1/2" to 3" or more. Depending on condition, wear etc, it may give you different readings over the full range. While it is apart I would also check the run-out of the back plate when mounted to the spindle.
