    Dismiss Notice
Advanced Tool Sharpening for the Lathe by Conrad Hoffman
Discussion in 'QUESTIONS & ANSWERS (Get Help Fast Here!)' started by Nels, Sep 23, 2011.
  1. Nels
    Nels United States Founder Staff Member H-M Supporter-Premium
    763
    113
    Eastern Queens, NY
    City:
    Eastern Queens
    State:
    New York
    -Return to Top-
    http://www.conradhoffman.com/advancedsharp.htm
    Advanced Tool Sharpening for the Lathe with Special emphasis on Threading Tools
    Many people create HSS lathe tools using nothing more than a bench grinder and get perfectly acceptable, if not downright excellent, results. For most normal sized projects with moderate tolerances that may be all you'll ever need. As tolerances get tighter, or improved surface finishes are required for decreasing part sizes, better tools are needed. You can't shave tenths and simultaneously get a great finish with a dull tool.
    My goal is to show you some practical techniques that can quickly be applied to improve the edge quality of your tools. The techniques are neither authoritative or backed up with extensive research. They are simply things I've picked up over a good number of years building close tolerance assemblies, scientific instruments, plus reading and watching how other machinists, some having far more knowledge and experience than I do, make things. With some thought you may well build on, and improve, the ideas covered here.
    It should be mentioned that my focus is exclusively on generating extremely sharp edges and you can't blindly apply that type of tooling to every situation. Razor sharp edges are exactly what you don't want in most high speed production situations with stainless steel and other alloys. This tooling isn't for roughing or for cleaning the scale off mill finish steel. These edges won't have the durability needed for volume production.
    So when do you need these tools?
    •When there's a need to control size at the tenth level or below.
    •When taper is a problem with unsupported stock and you can't use a center.
    •When stock tends to work harden during cutting.
    •When making adjustment screws of any pitch where smoothness and fit is important.
    •When making fine threads in excess of 40 TPI.
    •When making threads where low friction is important.
    Tool angles are well covered in many places, from Southbend's How to Run a Lathe, to the web, to Machinery's Handbook, so I won't spend time on finding the perfect rake angle for cutting 6061 aluminum. Information on how to achieve maximum sharpness of cutting edges is a lot harder to come by, and that's the real topic of this page. I have to add that we all seem to have absorbed a lot of erroneous folklore concerning sharpness, starting back when a well meaning friend or relative showed us how to sharpen that first pocket knife. A conversation about carbide tooling is also in order, as its an option with many strengths and pitfalls, especially for the home machinist.
    The exact details of what happens when we "cut" metal is also outside the scope of this page, but the reader is encouraged to do some additional research. Start with the search term "mechanics of metal cutting". If you look at the cutting action of the typical lathe tool, you'll see that the actual cutting takes place along a line, and usually a very short one at that. The line may be bent and have a radius, but as long as sufficient relief is present, what happens 25 thou away from that line is irrelevant to the process. Thus, when we talk about tool angles, it's the angle right at the cutting edge that's important. Everything I present below is an attempt to control the geometry in that tiny area of the tool where cutting takes place.
    You Can't Get a Good Edge Sharpening Freehand
    It only takes a single pass on a stone, or a millisecond at the grinder, at the wrong angle, to destroy the geometry of the cutting edge. There is no way to sharpen freehand and get a quality edge. You have to use some kind of guide system. I can already hear the Crusty Old Machinists calling me an idiot and making all sorts of claims about how they can shave with their freehand sharpened tools. The fact is, they can. Why? They cheat. They use a guide system, whether they realize it or not.
    The neophyte often rocks his tool all over the grinding wheel due to lack of skill and practice. The Crusty Old Machinist may do the same thing, but only to increase the metal removal rate when roughing things out. After that, he usually keeps the entire face of the tool in intimate contact with the wheel. You'll see only a hollow ground area with a single radius on his tools. As the he brings the tool to the wheel, and especially when he removes it, he's careful not to grind on the cutting edge. Thus, even though he may not realize it, the cutting edge is being protected by the inherent guide system of the curved tool face riding against the curved grinding wheel. It's not perfect, but it's a technique you should master because it leads to the next step of refinement.
    Here's about what a tool should look like coming off the grinder. You would also want some top rake and maybe a chip breaker for most applications, but note the clean and slightly curved faces. This was ground on an ordinary 8" off-hand grinder using no rests at all. The main (side) cutting edge is the one facing you, though the tool will also cut very well the other way, if the depth of cut (DOC) is small.
  2. briank
    briank Dominica Active Member Active Member
    0
    6
    City:
    Ottawa
    State:
    Ontario
    -Return to Top-
    Thanks for digging this stuff up, too beat tonight to look at it but it's great stuff for us newbie's.
    Will make a note and return to it later.
    Thanks again
    brian
  3. itsme_Bernie
    itsme_Bernie United States Active User Active Member
    69
    48
    City:
    NNJ
    State:
    New Jersey
    -Return to Top-
    I am "bumping" this because it is awesome to read, and I just learned a lot.
    Bernie
  4. rebush
    rebush United States Active User Active Member
    0
    16
    City:
    Naples
    State:
    Florida
    -Return to Top-
    Nelson: Once again you've went over and beyond. Thanks so much for taking the time to prepare such a great article. I know I learned alot. Roger
  5. Morgan RedHawk
    Morgan RedHawk Active User H-M Supporter-Premium
    32
    28
    City:
    Columbia
    State:
    South Carolina
    -Return to Top-
    Bumping again, because as someone that is learning the skill of tool grinding, this is very informative and helpful. Yall should make this a sticky.
  6. q20v
    q20v H-M Supporter - Premium Content H-M Supporter-Premium
    67
    18
    City:
    Ottawa
    State:
    Ontario
    -Return to Top-
    Thank you very much for posting this. As a relative beginner there is a lot of good information in there!
    Barry
  7. royesses
    royesses United States H-M Supporter - Premium Content H-M Supporter-Premium
    280
    63
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    Awesome thread. Thanx for making this available!
    Roy
  8. rock_breaker
    rock_breaker United States H-M Supporter - Premium Content H-M Supporter-Premium
    73
    28
    17954 CR 15
    City:
    Yellow Jacket
    State:
    Colorado
    -Return to Top-
    Thanks for the fine thread, very informative. I just bought a used Enco tool grinder now I find out I don't need it? I am sure it will be useful in end mill sharpening as well as lathe tools. I am just going to re-study your article as I encounter various situations.
    Thanks for your excellent work
    Ray
  9. clevinski
    clevinski Active User Active Member
    12
    18
    City:
    South River
    State:
    New Jersey
    -Return to Top-
    Outstanding info! Thanks for posting...
    DKD228 likes this.
  10. intjonmiller
    intjonmiller United States H-M Supporter - Premium Content H-M Supporter-Premium
    673
    93
    City:
    Layton
    State:
    Utah
    -Return to Top-
    This just came up in a search for something else. It's funny because I just found this on the web yesterday. It learned A TON from his writeup. I actually used it today during lunch to hone some ancient (but very well-ground) HSS tools that came with my lathe. I figured it was worth a bump again for anyone else out there browsing who hasn't read it before.
    Also note that if you go to his site he has the plans drawn up for making that sharpening jig, and it's easier to read on his site, with the words and photos together as appropriate.
Share This Page
