- Oct 27, 2013
- 124
Hi;
I have time and scraps to build a knurled roller grain mill, for crushing barley for my favorite hobby, home brewing of beer. There are some very good stainless roller models, that use 6061 aluminum plate for the ends. Thay retail for around $150-200, (for instance the Monster Mill MM-2), but I want to build my own with slightly longer rollers that I may power with a 1 HP 120v electric motor, a 1/2" power drill or even a hand crank. Problem is that I have no understanding of how the "on the fly" gap adjustment works.
Most of the commercially available models have 2 rollers. One is driven and the other freewheels. The knurled surfaces of the rollers insure that the grain is grabbed by the driven roller and pinched as it is crushed, thereby driving the free wheeling roller. More advanced versions for larger operations, like micro breweries, use gears to drive all rollers and some even have 3 roller set ups. I'm fine with a 2 roller system as I'll likely only grind 20 pounds or so of grain at any given time and since it's a hobby a few more moments crushing grains once a month is no big deal even if I have to run the grist twice to get the proper crush.
The interplay between the rollers has to be adjustable. Different types and differing moisture content of various grains need differing amounts of pressure (distance between rollers) as there is no 100% universal gap that always works best for each grain type.
I own a stainless counter mounted pasta noodle roller that works on the same principle I'd like to build. One rotary knob changes the interplay at both ends of the roller, keeping the axels of the rollers perfectly parallel. It's ends however are stamped stainless steel sheet metal. If I take it apart and for some reason can't get it back together correctly, just to see how the adjustment knob changes the spacing, I'll be upset.
I could machine a bearing slot in the end plates and use some sort of jack screw set up to change the interplay, or a dual cam device (one on each end plate) that has an exterior tie bar but the one knob adjuster in the pasta roller and the Monster Mill is so slick. Can anyone begin to help me understand how it works? Maybe a sketch of the mechanism?
