    Dismiss Notice
Adding an On-Off Switch to Fowler Digital Caliper
Discussion in 'METROLOGY - MEASURE, SETUP & FIT' started by old toolmaker, Jun 25, 2017.
  1. old toolmaker
    old toolmaker United States Active Member Active Member
    32
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    Hi,
    I want to add an on-off switch to a 6" Swiss made Fowler digital caliper. I acquired this caliper from my father when he passed away about 14 years ago. It is really a nice measuring tool that has seen little use. It has one annoying issue that I would like to change and that is the caliper has no shut off switch and you guessed it; the battery goes dead too soon. I searched the active topics of this forum and have not found an answer for what I want to do. Does anyone have experience adding an on-off switch to one of these calipers? Or am I wanting to do something that is not worth the effort?
    Dick
  2. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,394
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    I think I would make a thin plastic shim to fit one side of the battery if it could be easy enough to get in and out.
    Tozguy likes this.
  3. extropic
    extropic United States Active User Active Member
    149
    43
    City:
    Kalama
    State:
    Washington
    -Return to Top-
    I'm curious if the caliper has auto-off that isn't functioning or if it's designed to be ON all the time.
    The latter seems so unlikely to me, especially for a Swiss made tool.
    Are you saying that digits display all the time, until the battery dies, even when the caliper is unused/unmoved overnight?
    In the past, I've seen a chart that showed the capacity of various button cell part numbers.
    There are some (different PN) button cells with the same physical size but not the same capacity.
    You might do a little research to verify that you're using the best battery PN option.
    From Wikipedia: "Cells of different chemical composition made in the same size are mechanically interchangeable. However, the composition can affect service life and voltage stability. Using the wrong cell may lead to short life or improper operation (for example, light metering on a camera requires a stable voltage, and silver cells are usually specified). Sometimes different cells of the same type and size and specified capacity in milliampere-hour (mAh) are optimised for different loads by using different electrolytes, so that one may have longer service life, than the other if supplying a relatively high current."
    https://en.wikipedia.org/wiki/Button_cell
    Anyway, my recommendation for a switch is to simply remove the battery at the end of the day.
    Tozguy likes this.
  4. Tozguy
    Tozguy Active User H-M Supporter-Premium
    736
    113
    City:
    Drummondville
    State:
    Province du Quebec
    -Return to Top-
    If you have found that the battery goes dead then can we rule out an auto-off feature?
    Maybe check with Fowler to confirm the right battery to use and how to improve battery life.
    If it really does not turn off somehow Fowler would have fielded this question many times over the years.
  5. Groundhog
    Groundhog United States H-M Supporter - Premium Content H-M Supporter-Premium
    301
    63
    City:
    Salina
    State:
    Kansas
    -Return to Top-
    Seems to me that I've read that most calipers do not completely turn off, they just turn off the display (which is likely the biggest battery user). Don't know what this has to do with your situation though !? :distrust:
  6. old toolmaker
    32
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    There is no auto off function that I know of. The unit never turns off until the battery is completely dead. This is the only caliper I have ever seen that does not have auto off or a switch.
    I may check to see if I could cut a little slot in the case cover to allow me to insert a thin plastic shim over the battery contact. I know this would be pita to do every time but short of getting another caliper it might be the best solution.
    I might also try to contact Fowler.
    Dick
  7. markba633csi
    markba633csi United States Active Member Active Member
    315
    63
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Of course you can add a tiny switch but it may not be pretty. You might be able to make a "wafer" that would insert between one side of the battery with two very thin wires trailing out to a tiny switch. That would probably require the least amount of modification to the caliper itself. Like a small piece of thin double sided fiberglass circuit board. I might have some of that around here somewhere...
    Mark S.
  8. markba633csi
    315
    63
    City:
    Mountain View
    State:
    California
    -Return to Top-
    There are very small switches available like this: tinyswitch1a.jpg tinyslidesw1a.jpg I think I have some of the slide type I can send you if you want to experiment- cost of postage
    Mark S.
  9. Tozguy
    736
    113
    City:
    Drummondville
    State:
    Province du Quebec
    -Return to Top-
    It just occurred to me that the turn off might be a press and hold feature on the zero button or mm/inch button, or maybe press twice or something like that.
    higgite likes this.
  10. higgite
    higgite General Manger - Proofreading Dept. Active Member
    500
    93
    City:
    Houston
    State:
    Texas
    -Return to Top-
    It wouldn't surprise me if that works. I have some digital indicators that you turn off by holding the "on/zero" button down for a few seconds.
    Tom
  11. old toolmaker
    32
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    Guys,
    I am going to check that caliper out tomorrow to see if it will shut of with a press and hold or something like that. It is definitely worth a shot.
  12. old toolmaker
    32
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    I don;t have a user manual so I went online and did a search and got the scoop.
    This is a high class caliper but it has no ON OFF switch and the battery life is stated as one year. I guess that will have to be good enough for me although it seemed to me I was replacing the battery more often that that.
    Maybe that was caused by the fact that my shop was unheated during night hours here in Minnesota during the winter months. Most batteries don't like cold.
    Dick
    Tozguy likes this.
  13. Tozguy
    736
    113
    City:
    Drummondville
    State:
    Province du Quebec
    -Return to Top-
    Shucks, no off switch. Thanks for the feedback though.
Share This Page
