I use an iPad most of the time. At the bottom of the box where you've composed your post there are three buttons: Post Reply, Upload a File, and More Options. Click the Upload a File button. A dialogue box should open with a button that says Choose File. Click that, and another box opens asking where you want to get the file from. I choose Photo Library, and when I click that my photo albums open to select the image. Select an image, click the little box that says upload file, and the image should load. I do one image at a time, same process just repeated.
You also have a choice after the image has loaded to show it as Thumbnail or Full Size. I choose Full Size as some folks can't always see the thumbnails. Once you're done loading photos, click the Post Reply button and your post should appear.
Hope that helps. You can play around in the practise forum to get the hang of it.
-frank
