  • Guest,  We want to wish You and Your Family a Healthy, Happy Thanksgiving! Click the "X" at the top right corner to remove this notice)
4
Acme or UTS Thread
3
Like what you see?
10
ddickey
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Apr 21, 2016
1,006
Likes
506
#1
I suspect no one is following this thread of mine so I thought I'd repost and get some suggestions. Here is the original thread link.
http://www.hobby-machinist.com/threads/toolmakers-vise-material.63310/
I do not have any acme taps or dies for the lead screw. I do however have some left over 5/8-10 RH acme precision rod left over from my surface grinder job. I could buy a brass insert and press it into the lead screw block. Then I could buy a few acme nuts to fit onto the screw to make my handle proper.
The other option is to just single point a 60° thread.
Suggestions?
4gsr
HM Chief Foreman
Staff member
Aug 8, 2011
4,406
Likes
2,666
#2
Why not single point a Acme thread screw, then make a nut where the ID would be Acme thread for the screw. Then thread the OD of the nut with a 60 degree vee thread. That way, you could drill and tap a UNF thread in the vise body, lock in the brass nut with Loctite and you go it!
Be nothing wrong with making the screw thread a 60 degree vee thread for the vise.
ddickey
Apr 21, 2016
1,006
Likes
506
#3
Yeah I think we're on the same thought process.
What TPI would you use if you single pointed it? SInce I would be making both the A and B threads I could make any TPI I wish. 20TPI?
4gsr
HM Chief Foreman
Staff member
Aug 8, 2011
4,406
Likes
2,666
#4
What's the OD of the screw you want to use?
ddickey
Apr 21, 2016
1,006
Likes
506
#5
5/8-10 Acme is the screw I have left over. I would stay with 5/8 if I single point thread also.
4gsr
HM Chief Foreman
Staff member
Aug 8, 2011
4,406
Likes
2,666
#6
Okay, with 5/8-10 Acme, I would look at making a nut with a OD thread say 7/8-14UNF, so that way you could use a standard tap to tap a hole in the frame of the vise.
[6]
5 [7]
