A Small Rope Pulley For A Sail Boat
Starlight Tools
Sep 22, 2010
898
Delrin is the prefered choice of material for rope sheaves, but looked good for what you made.
Walter
Delrin comes in White and Black Common Name is Acetal.
My supplier usually carries the white, so that is what I keep in stock.
Here is a spec sheet on it.
http://www.plasticsintl.com/datasheets/Delrin_150.pdf
Walter
Walter
Do you think the Acetal would hold up with an anchor rode rolling on it, 20' of chain is attached to the anchor?
I now have aluminum pulleys that are in need of replacing and this seems like a good replacement.
Mike
Just about every sheave on the sailboat is made from Delrin. Very tough material.
There is an immmense amount of friction forces on the sheets (sheets are the lines that are used to control the sails) and over time the delrin gets worn away.
It is what I would probably use for that application.
My other thought would be the hard neoprene rollers that are used for boat trailers, etc. One with a wide Vee would probably work well and would handle the roughness of the chain.
Walter
Walter
Thanks Walter
High Molecular Weight Polyethylene might be worth checking out. It machines well, but doesn't respond to sanding. Very abrasion-resistant. As a pulley for rope and/or chain, I think it would work well.
