B
BRIAN
Forum Guest
Register Today
Have you ever wanted to make a clock BUT came up with a list of problems like .
Cost of brass---cost of cutters--plans- dividing head---I havent the knowledge --ETC ETC.
Have you a lathe With very little accesories, and wonder what you can make.
In this project I will be using only my basic 7x12 as it came in the box--a small bench drill-- A Dremmel type mini drill. And the normal hand tools found in a shop.
If we need other tools we will make them, But we are not going to spend a lot of the green crinkly stuff.
:nono:
Many plans start with a simple clock design then try to make it on a lathe.
But I have turned this around, saying, what can I use on this lathe and drill, to make a clock.
The design of the gear train allows all the gears etc on this clock to be made by direct indexing from the 60t and 80t gears that come with the lathe
no fancy compound gearing to get the right tooth count.
The design will be based on Janes Clock but with a lot less brass, only the gears will be of brass.
the frames etc will be blued steel I expect the cost to be less than a 1/3 of Janes Clock
The first test gear has been made with a home made cutter so i am on my way!
I have just rememberd I havent compressed the photos so I will do another post with them in.
:nuts:
Brian.
:nono:
:nuts:
Brian.
