- May 4, 2015
- 3,583
Congratulations , super looking mill.
That's a good looking milling machineToday wasn't as productive as I'd hoped but I did get some more done. I was able to get the X and Y axis DRO scales on as well as the display. Figured I'd start with the easy axis and go from there. I put welding magnets on either side of the table and set the scale on them. It worked great for getting my bolt holes marked. I installed the reader with some aluminum angle iron I had. Never got a picture of the reader angle mounting because it's pretty basic. If someone would like a picture of it just let me know and I'll take one for you.
The Y axis was a little more tricky but the link Mark posted had some great ideas. I decided I would build something rather than try to fit all the angle plates together that come in the DRO kit to make it work. I also wanted the mounting to be solid. I found a piece of aluminum and slotted it out to fit around the lead screw.
I then moved the Y axis in all the way and back out to find where I needed to mount the reader so it was centered. It needed to be mounted on the right hand side of the plate so I took it out and trimmed off the left side and added some slots for the angle plate to mount to. I installed the plate and mocked everything together to find the best place for mounting the scale.
If you didn't notice, The counter-sunk cap screws on the plate were replaced with hex head bolts. Seems I drew the cut-off on the wrong side of the plate. I didn't have enough meat left to counter-sink again so just I just wacked my head against the wall and went and found some bolts that would fit......
I figured I'd wait till tomorrow to tackle the Z axis so I mounted the screen and arm to the mill. Once I have the Z axis mounted, I'll get the cables tied up and out of the way properly.
And just another one of the scale mounting.
The more I work with this mill, the more I'm liking it. I'll get my vise mounted in the center of the table tomorrow. I mounted it the way it is so I would have enough movement for checking scale mounting.
Hopefully over the next couple of days I can get a proper electrical box put on with a few 120v plug-ins for the power feed and DRO. I think I'm going to put 6 plug-ins on it for expansion. I do plan on adding a Z power feed and may even add one on the Y as well.
