So I have 6061 rotors with neodymium magnets in them.
I want them to not spin on the shaft so at least an interference fit.
I believe that would be .005 and freeze the shaft first since I can't heat up the magnets (275 degrees) without damaging them or the glue.
What other methods can I use knowing the shaft is 1 inch and the rotors are 1/2 inch apart.
Would a keyed shaft be safe at 20K rpm?
Or I could limit myself to much lower RPM.
But the only tools I have at my disposal are a Bridgeport CNC (Series 1 retrofit) and my desire to succeed.
So splining a shaft and the rotors is probably beyond my level but I can always use an online shop if I have too.
I have done well at all other aspects of the motor (speed controller build, winding fabrication etc.).
Thanks JC
Thanks JC
