- Mar 15, 2015
- 119
Finally getting my lathe set up. My precision level came so I was able to level it and decided to get a new chuck as the one that came with it was a 6 inch that has seen some use. I decided to get a 8" 6 jaw adjust tru from Shars. I turned the back plate for it so that it was snug - I had to use the bolts to pull it up tight. It had .0015 for run out so I decided to take another .008 off. I used a 1.5" Danly die post to adjust the run out.
I also got a 5c collet chuck with a D1-4 mount. The run out was supposed to be .0006 but turned out to be .008. I got this from toolsprecison on ebay and later found out it was actually CDCO in Illinois with another storefront. I think from now on I'm going to have to really check out who the store front belongs to before buying.
