Well my 5c block didn't come with a wrench and I didn't wanna spend 30 buck on one. so I made one from some 3/16 flat bar and a grade 8 bolt I trimmed down in the lathe for a pin. I found a hole saw bit close to the nut drilled it cut and sanded the body and welded on the pin works like a champ
