I have an Index vertical mill that is wired for 440 volt operation. The wires from the motor are tagged with double digit numbers. The motor is two speed as well as reversible. I know that on 440 v the motor is series hook up. 220 volt it is parallel hook up. But with the reverse and two speed it has me confused. Any help here? Most wiring I understand except for some motor wiring.
Thanks, sitn
Thanks, sitn
