- Jul 22, 2017
- 9
I recently ordered this kit (~$185) from GearBest, http://www.gearbest.com/3d-printers-3d-printer-kits/pp_428455.html .
... Don't ignore caveats to keep your filament dry as I did. It's hydoscophic and will absorb water over time resulting in progressively worse prints. I build this to dry out my filament:
http://taulman3d.com/drying-materials.html
Also, I bought a ~10lb bag of dessicant (kitty litter:) to store my filament when not in use. Hope this helps.
Thanks for the tip on the Silica cat litter! I was starting to look for a cheap source -- the packets are expensive!
I also built the Taulman dryer out of a Home Depot "Homer" bucket. It works, but I find that a full reel gets a little too warm near the bulb (visibly alters PLA slightly), so I plan on making a bigger/better version from a medium sized galvanized garbage can (10 gal or so?) to hold more filament reels and give a little more distance from the heat source (maybe add a small fan to circulate the heated air).
I'm also eyeing my wife's foodsaver, which doesn't get much use... no point in drying out the filament only to let it re-absorb moisture. 1-Gallon Ziplock bags with dessicant are probably good enough, but as long as the foodsaver is just sitting there taking up counterspace ...
