- May 26, 2015
- 754
The Grizzly 3-In-1 Drill/Mill is a very inconvenient machine to be able to use the milling spindle. The spindle does not lower down very far to be able to use it adequately. A riser of about 2.5"-3" would be good. Does anyone have any ideas on a riser to be able to mount various vices higher up off the table? The commercial table risers I've seen are pretty expensive! a "3x6"x7" block of 6061 aluminum would be adequate. If you have figured it out I'd like to see some pics or suggestions for an economical riser. Thanks
