Paul--I have the same problem as you except mine is much worse---my breaker panel entrance is on the front of my house and my two separate detached shops are on the rear side--neither shop has 220 wiring and only one line of 110 services both shops--that works only nice for lights and small motors--my AC unit is on the rear side of my house but I'm sure it is only for approx 35 amps--I need 220 50amp for my welder and I need 220 for my air compressor and one lathe and two mills--so I will have to run approx 200 feet of underground cable (probably at least #6 or larger)--I figure my cost of materials will be $400-$800 and I can't justify that expense till I sell some things---anyway-If I were you I would definately put the 220 wiring in your shop instead of messing with 110 headaches--they won't help when you need 220 for welders --compressor and other shop devises---you didn't say if your shop or garage is attached to your house or not---hopefully your service panel is in a better location than mine is--I don't even have a basement or crawl space to run it under my house--I will have to go up and through the attic area to get it to the back side of my house----Dave
If you have a dedicated outlet in the shop area you could rewire it for 220V. All you would need is the receptacle and new breaker.
That would violate code by making the white wire in the circuit hot. White is, for very good reason, reserved for grounded conductors. Besides, he'll want 120 in the shop for other stuff.
Code calls for marking the wire most wrap black electrical tape on both ends to show it's hot.
Now most are going to a 4 wire which is a waste neutral and ground go back to the same place it's to be sure it's grounded.
Todd
It's not a waste, there are very good reasons.Code calls for marking the wire most wrap black electrical tape on both ends to show it's hot. Been done that way for years. Now most are going to a 4 wire which is a waste neutral and ground go back to the same place it's to be sure it's grounded.
Todd
And then the tape falls off or the homeowner messing with the circuit has no idea why it's there and ignores it. Not a good practice at all. I do this with cord sometimes but I use magic marker, not tape. I won't do it with Romex or wire in conduit, though I concede that it is legal.
It is code compliant to use the white as a hot with marker tape to indicate it is not a neutral. Same as marking a switch leg. Probably more correct than using a marker. Is the marker listed for that use? Most markers are solvent based. What does the ink do to the insulation over time?
I only offered an easy solution to his problem if he had enough circuits in the shop that he could afford to loose one of them.
