- Jul 30, 2017
- 474
So on my Logan lathe, model 1875 built in 1957 - I am currently restoring It and found a cool looking banjo gear that has an offset ( mold shifted i'm guessing ) my concern is that theres is allot of metal ( weight ) in one area and less metal at the other side, Should I get a replacement..? or is this trivial.. Also the teeth at the bottom have virtually no metal backing for support. will this weight offset cause vibration - the gear has no marks at all so I doubt its ever been used.
What say you..! keep or replace..?
I'm guessing I cant get it replaced under warranty Logan has it in stock $150.00 - Thanks Mike.
