- Jun 12, 2014
- 4,828
FYI, this came up recently regarding a G4003G. I would review the thread below, but the bottom line, probably 2000RPM to be on the safe side, unless QMT say you can go higher and not void the warranty. Heavier oil, in contrast to what one would assume, performs worse at the higher speeds with splash lubrication. It's a matter of getting the oil to the lathe bearings, and not the bearings themselves. Also the drag and heat formation can go up significantly with the heavier oil, and I have read a number of accounts that did not have good outcomes. Grizzly lathes and many other brands run ISO32 oil in these smaller lathes. Better off to use your 8K for high speed.
http://www.hobby-machinist.com/threads/maximum-safe-rpm-for-a-grizzly-g4003g.34408/#post-291473
I am going to purchase the tru-setting 5C D1-4 chuck from Lathemaster, very reasonable if the quality is decent.
http://www.lathemaster.com/lathemaster 5c collet chuck.htm
