I don't know other's agenda,but I would never plan that a lathe only had a certain job. Things change and needs change too much for me to not need the flexibility. I was able to do a very lucrative job in my 16" lathe a while back when I had to swing 24". Just barely got the job into the gap.
I will say that not every gap will always go back in perfectly. We had the same model of my home lathe at work. ONE serial number apart. I removed the gap once. Careful as I am,and as clean as I got all the surfaces before reassembly,the gap in the lathe at work would NOT quite go back in perfectly flush. I removed mine with trepidation,did the job,and fortunately,it went back absolutely flush,thank heavens!! It is the only large lathe I have,or can afford right now. Most of the time I use my HLV-H,but there is nothing like a larger size lathe when you need it. My lathe at home also faces dead flat as well as turns perfectly true cylinders. The one at work faced a little hollow,but within Gov't. specs. I prefer a lathe that faces flat. I don't do pipe flange work(which is why lathes usually face a little hollow). I had no way to test either lathe when they were in crates. I just got lucky.
