- May 4, 2015
- 3,583
Label your boxes and switch panels is always good. I wire a separate switch box on each machine . It's closer if you working using the machine and some problem comes up. A separate box marked lights and voltage isn't expensive. Better to safe then to sorry. Every shop I ever worked or have been is has osha approval. Sometimes overboard but safe.
