Is it the fnr lever on the headstock or a lever on the apron? A pic would help.Could someone please tell me how to remove the spring loaded handle to the forward neutral and reverse lever? I hate to start beating or prying when there is no obvious method to remove. Thanks.
Same way, there is a long taper pin that runs through it and the shaft, scrape or wire wheel the paint off to find the pin and to determine which end is the small end and drive it out. Wack the small end with a short stiff punch to break it loose and drive it all the way out with a longer punch.The one I'm working on is on the apron, cannot see any way to remove from CI handle for polishing and painting. Sorry but my very old computer will not do pictures, A friend is going to give me his old windows XP the next time he is in the area so hopefully I'll be able to post a picture by the summer.
