- Oct 20, 2014
- 159
So I got sick of my part coming out wrong in the Y axis as far as not syncing surfaces up when flipped over in the vise and simply geometry being in the wrong place, so I decided to measure my vise deflection. Turns out its moving quite a bit, enough to explain what I'm seeing I believe.
The tools I used in the test:
-harbor freight in. lbs. torque wrench
-harbor freight ft. lbs. torque wrench
-homemade drawbar force gauge being used to measure clamping force
-Mitutoyo 0.0001" test indicator
I took the deflection from two spots, one right above the fixed jaw on the drawbar force gauge block which was in the vise, and the other, right on the top rear of the fixed jaw. Obviously the torque wrenches arent exactly NIST grade, but I'm pretty sure the force gauge is accurate. Regardless, everything is accurate enough to get a good enough idea what is going on. When I did the back-of-jaw data, I slid the force gauge over so its piston was centered in the vise.
After I did all the tests, I closed my eyes and tightened the vise to what I usually tighten it to (damn tight until I'd need to do a push up on it to get it any tighter)..the PSI went OFF THE GAUGE. Meaning Probably 3000+ lbs of force. I'm pretty sure thats overkill for the work I've been doing.
I've seen two interesting web sites about tuning up the cheaper vises. Neither one seems to offer any before/after data on deflection though.
Enco Vise Tune-up
Fixing the 4 inch mill vise
Before I did these tests, I took the fixed jaw off to see whats up. Didn't find anything shocking. I just filed lightly to remove any burs and put it back together. I replaced the two 8.8 grade bolts with 12.9 bolts and torqued them to 29 ft lbs (apparently the max. recommended). I found that they could be a bit longer too. there is a good 0.3" of thread left in the fixed jaw once they are tight. So I'll get some longer ones and maybe it will help a little. I might also explore upgrading the bolt size to bigger, like one of those threads shows, but I dont have another vise so I might run into trouble using my mill to do the work.
I am not badmouthing this cheap-o vise. It was about $100 from some no name ebay seller about a year ago. Its been my workhorse and has taken me VERY far. And from what I read about kurt vises, deflection of this sort is still a reality even with those. I'm not sure what the kurt 4" deflection vs. force relationship is, but its not a horizontal line.
EPILOGUE:
I have now started using a $9 horrible freight torque wrench to tighten the vise during my setups, and only use the standard vise handle for loosening the vise or if I need to move the vise jaws a large distance and take advantage of its U joint.
The torque wrench lets me create consistent and proper clamp loads, which reduce vise deflection and make the accuracy and repeatability of my setups go way up. Its a major improvement. Alot of my work involves multiple vise-aligned setups where the tilt of the part in the vise cant be easily compensated for by zeroing off a particular machined location.
I'm not sure how much these tests indicate the quality of the vise either way, or how much they would improve with a more expensive vise. All vises deflect. Kurt does make a 4" vise with a one-piece fixed jaw (no key or bolts), which would surely have better deflection, but its $1100. I think in this case, as usual, proper setup and planning can equal or exceed counting on superior specifications of better equipment.
Now if you were doing a cut that needed 3000 lbs of clamping and had to be aligned within 1 thou when it was flipped over, blind, the vise accuracy may play a more important role. But for small machines with lower clamp load requirements, a more rubbery vise can probably get the job done if used properly.
[/QUOTE]
Enco Vise Tune-up
EPILOGUE:
[/QUOTE]
